Connecting cloakroom pedastal basin waste pipe to wall outlet constricted space
abingdonbodger
by abingdonbodger » Wed Mar 16, 2022 8:07 am
I have a telescopic P-Trap but its outlet is very close to the wall outlet so it's difficult to connect the two. Currently the only solution I have is an McAlpine flexitube but that puts a lot of sideways pressure on the p-trap.
I am thinking of changing to a bottle trap as it is more compact but horror its outlet is female push-fit but my flexitube is expecting to screw on (I would need a flexitube with two male endings). (see photo)
Any advice welcomed. Everything is 1 1/4 32mm.
(I'm starting to really respect professional plumbers!! I couldn't find one who was available)
about 7 cm from outlet
Re: Connecting cloakroom pedastal basin waste pipe to wall outlet constricted space
by stoneyboy » Thu Mar 17, 2022 10:55 pm
Hi abingdonbodger,
Buy a 11/4” compression elbow and if necessary rotate the trap to give the space needed.
abingdonbodger
by abingdonbodger » Fri Mar 18, 2022 7:45 am
Hi StoneyBoy
My solution turned out to be to use a Bottle Trap which is very compact and gave me a few more CMs to play with and a shorter flexi-Pipe.
(the wrong type of connector ends was probably just my experience)
Abingdon Bodger...
Now I've got to do some tiling!!!
by stoneyboy » Fri Mar 18, 2022 9:58 pm
Hi abingdonbodger,
Thanks for letting us know how you solved the problem.
It is currently Mon Dec 02, 2024 4:56 pm
