Do I need thicker flex if making it longer?
glock339
by glock339 » Sun Mar 20, 2022 2:29 pm
I'm sitting up a load of LED lighting bars (2 different sizes) & they all come with the figure of 8 style flexes with moulded plugs that 1 metre long & are 0.5mm.
I was just about to swap these out 3 metre ones (0.5mm which I already have) then I thought I should check if I can stick to 0.5mm or would I need to buy something thicker? 3 metres seems nothing to me but I'm no sparky so thought I should check!
The larger units use around 60 watts & the transformer says "Output 21-33v 1200mA +3%".
Cheers!
Re: Do I need thicker flex if making it longer?
by Mr White » Sun Mar 20, 2022 10:24 pm
0.5mm cable on the mains side will be acceptable.
glock339
by glock339 » Mon Mar 21, 2022 5:57 am
Mr White wrote:0.5mm cable on the mains side will be acceptable.
Great stuff that'll save me a few quid, I just wanted to make sure I wasn't putting savings over safety.
Thanks for taking the time to reply.
It is currently Sat Nov 23, 2024 3:50 pm
