Weep holes around Drip Trays?
7 posts   •   Page 1 of 1
ChocolateTeaPot
by ChocolateTeaPot » Wed Mar 23, 2022 4:04 pm
Three cavity wall drip-trays are to be inserted side by side in a wall. Each drip-tray is the width of two bricks side by side. So, should I insert a total of four plastic weep-holes? This would give a weep-hole wedge at each end and two weep-hole wedges in the middle?
Thanks in advance for comments.
ChocolateTeaPot
Re: Weep holes around Drip Trays?
by stoneyboy » Thu Mar 24, 2022 10:47 pm
Hi chocolateteapot,
If you are using cavity trays with upstands at each end use one weep hole for each tray.
ChocolateTeaPot
by ChocolateTeaPot » Fri Mar 25, 2022 6:57 am
Thanks so much for replying .. should the plastic weep-hole wedge go in the middle of the tray?
CTP
by stoneyboy » Fri Mar 25, 2022 10:03 pm
Hi chocolateteapot,
Assuming the trays are around horizontal it doesn’t matter. You brick spacing will determine where they can be located.
ChocolateTeaPot
by ChocolateTeaPot » Fri Mar 25, 2022 10:05 pm
OK - thanks again for your help. Much appreciated.
CTP
Rob7256a
by Rob7256a » Sat Apr 23, 2022 10:54 am
Yes, vents/ weep holes go in the middle between the two bricks. Watch you don't block them with any mortar.
ChocolateTeaPot
by ChocolateTeaPot » Sat Apr 23, 2022 9:40 pm
OK and apologies for the delay in replying.
Yes, that's exactly how we did it.
Many thanks for your kind assistance.
CT
It is currently Thu Dec 05, 2024 3:22 am
