Siamp Flush inlet valve mechanism
waterbod
by waterbod » Wed Mar 30, 2022 1:41 pm
I have a problem with water overflowing into the overflow pipe and into the toilet bowl on a siamp. Due to a separate problem where the cistern was filling slowly, I changed the black washer (the old one was split) on the shut off valve. That solved the slow filling cistern problem. But then, this new problem occurred very shortly afterwards. I have noticed that the float connected to the grey threaded rod stays submerged when the cistern fills and I am assuming this is the problem. It rises a bit when the cistern fills but is totally underwater. If this is the problem, how is it solved? Do I need a new inlet valve unit?
Re: Siamp Flush inlet valve mechanism
by stoneyboy » Thu Mar 31, 2022 10:46 pm
Hi waterbod,
You may have adjusted the float setting while replacing the washer - try turning the grey rod to lower the float.
It is currently Sun Dec 22, 2024 9:27 pm
