Mains pump on tank to feed combi
comedydave
by comedydave » Sat Apr 02, 2022 7:09 pm
I currently have a 2bar shower pump pumping cold from my tank and hot from my cylinder to my shower. Now we're getting the house renovated, and one thing I'd like is to consider a combi boiler to save on storage.
I know I cannot use the shower pump with the combi boiler. However I'd like to maintain a decent head of water in the shower. Furthermore, the mains pressure is not ideal - I'm getting about 8 litres per minute from the mains to the kitchen sink (ground floor two storey house).
It was suggested to me that I use a mains pump on my attic tank (instead of on the mains) to feed the combi boiler. This would in theory give enough pressure to result in flow to the shower similar to what I have already. However, there are questions I have and am not sure how to answer them so looking for help here.
1. The tank in the attic is 50 gallon. Will putting a mains pump on the outlet of this run the risk of pumping it dry in no time? 50 gallons is quite a lot of water.
2. Would this result in too much pressure on the other hot water outlets (kitchen sink, bathroom sinks, bath tap) and result in drippy leaky taps (and a constant on-off of the pump as the pressure drops and it recognises that)?
3. How to choose what size mains pump? I see a 4bar pump - but 4bar seems quite a lot especially when the original shower pump was only 2bar
Any help appreciated!
Re: Mains pump on tank to feed combi
by stoneyboy » Tue Apr 05, 2022 10:54 pm
Hi comedydave,
Sounds like you have an old size mains coming to your house - probably 15mm or less. You could get the mains pipe upgraded to 25mm+ but this may not be cheap.
Leaving the mains supply pipe as is and pumping from the CWT may be the best solution. Use a variable pressure pump and you will be able to adjust it to suit your particular system however this is configured.
It is currently Tue Feb 04, 2025 12:58 am
