central heating valves
billbob
by billbob » Mon Oct 08, 2007 12:17 pm
i am moving radiator and changing from copper to plastic pipes (10 mm), in the connections to the copper pipe there is an olive but it too small to fit on the plastic pipe,is it necessary to have an olive or is the fitting tight enough without it.
adaze
by adaze » Mon Oct 08, 2007 3:46 pm
You need to use a plastic "push fit" connector. Make sure you use a pipe insert in the plastic pipe, then you simply push one end of the connector onto the plastic pipe and other onto the copper. Job done, shouldn't take more than a minute.
