How to repair rotted wooden door frame to fit new doors
mech_man
by mech_man » Sun Apr 17, 2022 9:40 am
I am in the process of replacing some internal doors and need some tips/advice as to how I can repair the existing door frames. The existing door frames are quite old and hinge cut-outs are rotted (see attached photos) so I can't use bigger screws or anything like that to hang the doors.
Just to let you know that I am not a joiner but I do a lot of DIY so I can carry out certain works myself.
I would be grateful ig anyone could suggest anything that I could try please.
Re: How to repair rotted wooden door frame to fit new doors
by stoneyboy » Tue Apr 19, 2022 12:02 am
Hi mech_man,
The top hinge location is not too much of a problem - take out loose timber, fill with 2-part wood filler and relocate the hinge up above the repair.
The lower area is much more difficult - see if there is any sound frame behind the door stop, if there is cut out all the rotten frame back to the door stop edge. Let in a new piece of frame timber then screw and glue it in place, if you can foam fill behind it. Cut the bottom hinge back in and “bobs you uncle”. If there is no sound timber you will have to replace one side of the frame.
It is currently Wed Feb 05, 2025 2:50 pm
