Deck footing depth and using post shoes
Ask questions and find answers on all your decking problems and issues
Bignose69
by Bignose69 » Wed Apr 20, 2022 9:06 pm
I'm building a deck attached to my house, it'll only be about 50cm above ground at the highest point but to extend the life of it as long as possible, rather than burying the uprights in the ground I'm looking at using these post shoes (pictured) in concrete. Anyone think these won't be ok? The fins will be buried 20cm into concrete, I can't see how that'll be any different than those concrete feet you can buy?
Re: Deck footing depth and using post shoes
by stoneyboy » Thu Apr 21, 2022 10:14 pm
Hi bignose69,
Your proposal should be fine but the clamp pockets will retain moisture which may accelerate rotting of the uprights. I have found that laying 100mm dense concrete block flat under each upright and dipping the upright in preservative before fitting work well.
Bignose69
by Bignose69 » Thu Apr 21, 2022 10:31 pm
Cheers mate
It is currently Thu Sep 19, 2024 1:28 pm
