cold water tank filling up
mary73
by mary73 » Mon Oct 08, 2007 2:48 pm
My cold water tank keeps filling up and not stoping. Any ideas of what the problem is and how i would fix it.
jackhawk
Re: cold water tank filling up
by jackhawk » Tue Oct 09, 2007 10:00 pm
[quote="mary73"]My cold water tank keeps filling up and not stoping. Any ideas of what the problem is and how i would fix it.
Thanks[/quote]
Do you have an overflow pipe and is it dripping or do any of your taps run when turned off? Your cwsc is continually filling because water is either leaving the tank via the overflow or a tap or leak. Have a good look around inside and out the house to see if you can spot any water. If you have two tanks in the roof see which one is filling. It could be your heating system.
Good luck
It is currently Wed Dec 25, 2024 2:16 pm
