Drilling holes through brick walls
Ask questions and find answers on a range of subjects relating to self build projects
rhino.fog
by rhino.fog » Mon May 02, 2022 9:51 pm
As part of my extension, I now need to drill out 2 x holes for the toilet waste, 3 x holes for shower and bath water, 3 x holes for 75mm MVHR ducting and 2 x 150mm holes for the MVHR outside connections. Most of these are through the old outside brick cavity wall.
Are there companies that I can get in to undertake this sort of work or what trade would have the equipment to do these?
Advice on my best options would be appreciated.
GR1587
Re: Drilling holes through brick walls
by GR1587 » Wed May 04, 2022 3:08 pm
For drilling the holes, I’ve just had a builder out to bore 5”holes for vents in my cavity walls so should be a similar job.
rhino.fog
by rhino.fog » Thu May 05, 2022 9:58 am
Thank you, I will post the job under general builders and see what responses I get.
I have found companies advertising Diamond core drilling but perhaps my job is a litle small for them.
It is currently Sat Nov 23, 2024 12:28 pm
