fitting a 16 Amp Socket
outdoorelec
by outdoorelec » Mon Oct 08, 2007 3:03 pm
Can anyone tell me how to fit a 16 Amp socket. Does it have to come from the mains fuse box or can i take it from an rcd unit tapped off an existing circuit? its for a hot tub and i have been informed that a 16 amp is better for the heater and pump, why is this. they told me that they could fit a 13 plug onto it which could connect to my outside socket but this wouldn't be as good. is there any truthe in this?
BLAKEY1963
Re: fitting a 16 Amp Socket
by BLAKEY1963 » Mon Oct 08, 2007 11:20 pm
[quote="outdoorelec"]Can anyone tell me how to fit a 16 Amp socket. Does it have to come from the mains fuse box or can i take it from an rcd unit tapped off an existing circuit? its for a hot tub and i have been informed that a 16 amp is better for the heater and pump, why is this. they told me that they could fit a 13 plug onto it which could connect to my outside socket but this wouldn't be as good. is there any truthe in this?[/quote]
OUTDOORELEC
A CIRCUIT DIRECT FROM MAINSBOARD , OFF A 20 AMP
MCB IF 16 AMP DRAWN BY HOT TUB.
R.C.D PROTECTED , 30 MILLI AMP TRIPPING RATED
COULD USE A 20 AMP RCBO.
IF YOUR TUB IS OUTDOORS THEN YOU PROBALY KNOW
THIS IS PART P WORK, SO YOUR PART P LECKIE
SHOULD ADVISE.
BLAKEY1963
It is currently Tue Jan 14, 2025 10:02 am
