Foundation advice for home gym
erfa
by erfa » Tue May 31, 2022 9:19 pm
Hello, Apologies if this is in the wrong section.
I'm looking for some advice regarding foundations.
I want to build myself a home gym, hopefully I've attached an image with the dimensions of the building. It will be built out of a single skin of 100mm concrete blocks with built in piers (either 3.6 or 7 newtowns depending on availability)
It will be a free standing structre (not attached to any existing buildings)
I was thinking of having a garage style foundation poured and wondered if that would be enough?
Screenshot (8).png (8.36 KiB) Viewed 1473 times
Re: Foundation advice for home gym
by stoneyboy » Sun Jun 05, 2022 12:33 am
Hi erfa,
If you are building on solid undisturbed land a raft foundation should be ok if thick enough. If you are building on built-up land or an old tip site you will need deep conventional foundations.
It is currently Sun Dec 22, 2024 3:29 am
