Secure timber frame to metal studs
Dave1970
by Dave1970 » Sat Jun 04, 2022 7:35 am
Hi, I need to build a timber frame to hold a door liner but its is in my daughters new flat which has metal studs behind the plasterboard. I've purchased a detector for cables and pipes but as the studs are metal this is not much use for pipes, I'm paranoid about drilling into a pipe, any tips how to avoid pipes would be very welcome. Thanks
Re: Secure timber frame to metal studs
by stoneyboy » Tue Jun 07, 2022 11:16 pm
Hi dave1970,
Drill carefully or cut viewing holes in the plasterboard which can be stuck back in place once you have done.
Dave1970
by Dave1970 » Wed Jun 08, 2022 4:54 pm
Many thanks, that's sensible
It is currently Thu Feb 06, 2025 9:01 am
