What fixings should I use to hang a ceiling mounted pull up exercise bar?
markcoulson
by markcoulson » Tue Jun 28, 2022 11:50 am
Going to install a ceiling mounted pull up bar in my gym room.
Ceiling is plasterboarded, above it is concrete reinforced.
I'll probably need 150mm long fixings to go penetrate through the wood joist (about 1100mm) and then probably 40mm into the concrete above it.
It'll be holding up to 100kg when someone uses it.
What fixing do people suggest?
Mark
It is currently Wed Feb 05, 2025 5:58 pm
