Do I have Efflorescence on my walls?
wanoennogs
by wanoennogs » Tue Jun 28, 2022 7:50 pm
So far I have tried a vinegar and water solution. I have also tried a chemical solution called salt away. I have used a jetwash afterward.
What I have tried has failed to remove it.
Do I have Efflorescence on my walls? If I do how do I get rid of it?
Here is a link to a photo of one of my walls
https://ibb.co/kxpJt3M
Re: Do I have Efflorescence on my walls?
by stoneyboy » Sat Jul 02, 2022 9:37 pm
Hi wanoennogs,
It looks like water is getting into the wall above the line of salts, this water is then permeating down to whatever the line of header bricks is laid on (presumably an impervious cement mortar) then coming to the surface carrying salts with it.
You could try cleaning it off with brick acid but it will come back.
It is currently Wed Nov 27, 2024 5:05 am
