Replace slates held on with slate hooks
Phil70
by Phil70 » Thu Jun 30, 2022 5:51 pm
I'm looking for advice on replacing a roof slate. Except for the first line of slates - which are nailed on - all the slates on my roof are secured using slate hooks. The broken slate I want to replace is in the middle of the roof - so it is hooked on and the top of it will be under the hook of the tile above.
I can pull it out as it is broken, but how would I get the new slate in?
Many thanks if anyone has any suggestions.
Re: Replace slates held on with slate hooks
by stoneyboy » Fri Jul 08, 2022 10:10 pm
Hi phil70,
If your slate hooks are the double bend type it should be straightforward to remove the broken one and slide a new slate in. Make sure you use a slate that is a couple of mill narrower than the gap.
Phil70
by Phil70 » Sat Jul 09, 2022 9:01 am
Thanks Stoneyboy! The hooks are in the form you describe - from what you're saying I guess there must be enough free play between adjacent tiles to be able to wiggle them out and back in again; I was concerned as from the cut-away pictures of how the slates lie using this kind of hook that they looked really tightly located, but your comment is reassuring.
Regards,
P
It is currently Sun Dec 22, 2024 12:52 pm
