Dripping kitchen tap but is this model serviceable?
Sclowes
by Sclowes » Sun Jul 03, 2022 5:58 pm
Hello, this kitchen tap appears to have no grub screw to release the handles. It is dripping and I wanted to inspect/replace the cartridges. Is this model no -serviceable?
Re: Dripping kitchen tap but is this model serviceable?
by stoneyboy » Mon Jul 04, 2022 11:30 pm
Hi sciowes,
There should be a fixing screw under the blanking plug in the end of each head work handle.
Sclowes
by Sclowes » Tue Jul 05, 2022 7:34 am
Thanks Stoneyboy. I’ve removed the blanking plates and the screws at the ends, but the handles don’t come off. Are they then supposed to slide or screw off?
by stoneyboy » Tue Jul 05, 2022 9:43 pm
Hi sclowes,
They are fitted on a splined shaft - should slide off with a bit of encouragement!
actoms
by actoms » Thu Sep 08, 2022 11:40 am
I'm not sure if you solved your problem but I have a similar tap (Franke Davos in my case) and have had to replace the ceramic cartridges on two occasions over the years.
On both occasions the cold tap handle slid off easily after removing the cover and the grub screw but the handle for the hot tap was stuck fast, having been 'welded' to the cartridge by the slow build up of lime scale.
Eventually freed it by forcing a gap of about 1mm between handle and body with a screwdriver and then dripping descaler onto the gap. (A small piece of insulating tape wrapped around the join with a gap at the top to drip the descaler into seemed to work). This took me two days, slowing opening up a slightly bigger gap.
Have now packed handle with grease and am removing it every six months to ensure no build up. Franke services were no help and a plumber suggested a new tap!
It is currently Mon Dec 02, 2024 1:56 pm
