Leak In Loft
Cathy
Leak In Loft
by Cathy » Tue Oct 09, 2007 8:42 am
Hi all, I have a leak in the join between the copper pipe and a copper nut that takes the mains water into my cold water tank.
Can I just turn off the stopcock and undo this nut and put plumbers tape around the joint and replace the nut without water spurting everywhere.
This sounds logical to me but its a bit scary not having done anything like it before?
Any advice would be gratefully received, hope you can help. Thanks
PhilC
by PhilC » Tue Oct 09, 2007 12:31 pm
Hi Cathy,
If the leak is on the feed side into the tank, and the stopcock is between the pipe and the mains then yes, turning off the stop cock will isolate that join.
Once you have turned off the stop cock there will be no water pressure to cause water to spurt out. There will be a small amount of water in the pipe and this could leak out so put a towel or something below the pipe when you undo the nut.
Be cautious though because if you have not used the stop cock much it may be stiff, or not turn the water fully off.
I would think the most likely cause of a leak is the washer holding the fitting to the tank rather than the nut. If the washer is still intact then just tightening the joint may work, but it may be better to replace the washer.
Alternatively you could try a couple of warps of PTFE tape around the end of the joint where it goes into the fitting and around the thread.
Good luck
P
It is currently Fri Nov 22, 2024 5:43 pm
