12V fused and switched distribution panel
Find help, tips and information on renewable energy sources such as solar, wind etc.... and also alternative energy & heating production.
cliver
by cliver » Fri Jul 08, 2022 8:27 pm
Hi all, New here. I am about to start installing a small, 100w off grid solar system in/on my shed. To start it will be just 12vdc to run a water feature plus internal and external led lights. In the future I may well expand it, add more panels, bigger charge controller and batteries plus an inverter to run some of my tools.
For now though, I just want advice on the best way to distribute the 12v. I want to be able to switch each item on/off and fuse each feed independently. Something like a caravan or RV control panel without the mains charger would be ideal.
Any suggestions or links to what you have used would be greatly appreciated.
Re: 12V fused and switched distribution panel
by ericmark » Thu Jul 14, 2022 4:07 pm
You can get DIN rail mounted fuse holders, I used them a lot so I could easy disconnect a section to test it, but an old consumer unit would do nicely.
As to the solar panel likely need a mppt controller, when I did it they did not exist, but the idea is it varies the voltage from the solar panel / wind charger to extract the maximum power. It also sets the charge rate for the battery.
Charging a lead acid battery is easy, but charging and using a lead acid battery is more of a problem, the standard way to charge a lead acid battery is using a stage charger, what it does is to bang in as much as it can until 80% charged then reduce the charge rate, it works out when 80% charged by the current the battery draws at a fixed voltage, if you use power, at same time as charging, it can fox the system and over charge the battery.
So the MPPT controller uses the voltage decay time when it stops charging to work out battery state, so less likely to over charge the battery.
As a DIY project, consider centre tapped battery, I used this with a hub dynamo off a push bike, output is 6 volt DC, so two half wave rectifiers, so positive half into one battery, and negative into the other.
The wheel was mounted to face up/down the valley, as wind never blows across the valley, and made the wind vanes by wrapping insulation tape around the spokes, latter version used a drum section to increase spacing. Not my idea, saw it at The Centre for Alternative Technology Machynlleth.
brantelyolivia1320
by brantelyolivia1320 » Sat Jan 21, 2023 5:29 am
A good option for distributing 12V power in your shed would be to use a solar charge controller, a battery bank, and a distribution panel.
The solar charge controller will regulate the charge going into the battery bank to ensure they do not overcharge. A 12V charge controller would be appropriate for your system.
The battery bank will store the power generated by the solar panels. It's important to use deep cycle batteries that are designed for solar systems.
A distribution panel with independent breakers or fuses for each load will allow you to switch each item on and off and protect each feed independently. You can also use a DC-DC converter, which is a device that steps down the voltage from the battery bank to the desired voltage for your loads.
There are many pre-made solutions available for this type of setup, such as those used in RVs and boats. You can find them online or in shops that specialize in solar equipment.
It is currently Sat Nov 23, 2024 10:43 am
