TV wall mount but crumbly walls
Roberto154
by Roberto154 » Wed Jul 13, 2022 12:55 pm
Trying to mount a 49inch TV bracket.
The walls when drilled produce black dust and just crumble. Solid concrete blocks probably.
Is there a recommended drill bit to combat this issue to fix securely?
thanks
Re: TV wall mount but crumbly walls
by stoneyboy » Fri Jul 15, 2022 2:59 pm
Hi roberto154,
You probably have a wall built with breeze blocks. Try using an oversize wall plug - one that needs hammering into the hole. If this doesn’t work you will have to use anchor bolts set in the holes using an anchorfix resin. Use a straw to blow dust out of the drilled hole.
It is currently Fri Jan 03, 2025 4:32 am
