Permimeter Drainage and Concreting Fall Under Window
6 posts   •   Page 1 of 1
Deathstar1991
by Deathstar1991 » Thu Jul 14, 2022 3:07 pm
Hello,
Had some problems with some tradesman and had to do some bits myself. Had the building inspector help out in areas as he could see I go screwed.
I'm in the last stretch and need a bit of advice. The path on the left is the neighbours and the brick garden wall is going back up. The external of the new clockwork has been tanked. Can I concrete under the window with a fall going into an aco drain running parralel under the window?
any suggestions?
Re: Permimeter Drainage and Concreting Fall Under Window
by stoneyboy » Fri Jul 15, 2022 9:53 pm
Hi deathstar1991,
Suggest that to make good you extend the accodrain and utilise the surface water connection (where the downpipe and gutter are discharging). Run a new pipe from the accodrain channel into the surface water connection. Concrete in with a weak mix. Fit an access plate on the top of the black pipe for maintenance and lay slabs to make good.
Deathstar1991
by Deathstar1991 » Sat Jul 16, 2022 10:37 am
stoneyboy wrote:Hi deathstar1991,
So carry the aco drain along and feed it into the inspection chamber?...
As the aco is set about 5/6 inches from wall running parallel what would I put behind here? Gravel?
by stoneyboy » Sun Jul 17, 2022 9:54 pm
Hi deathstar1991,
Provided the accodrain will be below DPC level, fill behind the acco channel with a weak concrete mix - you don't want the channel to move.
Deathstar1991
by Deathstar1991 » Mon Jul 18, 2022 12:40 pm
The dpc is bellow ground by about 3/4 inches. That's why the wall has been tanked internally and externally.
by stoneyboy » Mon Jul 18, 2022 10:33 pm
Hi deathstar1991,
Tanking will help but with your DPC below ground level you are likely to experience rising damp.
It is currently Sun Dec 22, 2024 4:12 am
