by Giveitago58 »
Wed Jul 20, 2022 10:05 am
I want to remove radiator for decorating. I've switched off both valves and undone the nut on right side but apart from a few drips, no water is draining. The nut only turns a few times before getting stuck, so I don't see how I will loosen it completely to remove radiator, once drained. I've loosened the air valve, but still nothing draining. What more do I need to do to drain radiator?
