Overboard plasterboard with thermal plasterboardboard
7 posts   •   Page 1 of 1
SusieRose
by SusieRose » Mon Aug 01, 2022 8:03 am
I live in a "Cornish house" The House used to be PC concrete on the ground level . This was changed to Cavity( brick & thermalite) in the '80s. The 2nd floor is tiled with an air cap that runs all around the house.(mansard roof) I have learned the top is insulated with polystyrene & plasterboard on one side, but the other side is just Plasterboard!!!. Can I overboard with thermal plasterboard or do I have to rip all of the plasterboards off ( I hope not) to achieve some type of thermal insulation for the house?
Re: Overboard plasterboard with thermal plasterboardboard
by stoneyboy » Fri Aug 05, 2022 10:32 pm
Hi susierose,
The issue is whether condensation will form in the original plasterboard if you leave it in place. You could minimise this by fitting a damp proof membrane (DPM). The construction would then be: old plasterboard; expanded polystyrene; DPM; new plasterboard.
SusieRose
by SusieRose » Sun Aug 07, 2022 10:33 am
Thank you for the reply, it has helped me a lot. I did wonder about the condensation due to the cold air travelling inside and up to the loft area.
by stoneyboy » Sun Aug 07, 2022 10:35 pm
Hi susierose,
You need the air movement in the gap all round you house to remove condensation.
SusieRose
by SusieRose » Mon Aug 15, 2022 10:51 am
Why is PIR board not useful instance, it has the foil protection to help with condensation.
by stoneyboy » Mon Aug 15, 2022 10:30 pm
Hi susierose,
Foil faced PIR board will work but it will cost you £10 extra per 1.2m x 2.4m sheet.
SusieRose
by SusieRose » Tue Aug 16, 2022 5:39 pm
Thank you for your expertise. I will follow your first reply to try and get some form of thermal insulation using the products you have stated. Thank you very much.
It is currently Sun Dec 22, 2024 5:30 am
