Regulations for rebuilding demolished building
Nav786
by Nav786 » Wed Aug 03, 2022 2:29 am
Need advice please.
I bought a derelict building 12 years ago. Building had roof totally collapsed in, external walls were still intact for few years before they also started to lean over. So i finally decided to demolish the whole building & get rid off all materials.
My question is can i build the same building again as it was 20 years ago? Or will i need planning permission? My concern is if I submit a new application then most likely planning department will refuse my idea. So i thought they might not refuse if i rebuild what was already there.
Re: Regulations for rebuilding demolished building
by stoneyboy » Sat Aug 06, 2022 9:45 pm
Hi nav786,
You may have shot yourself in the foot, your local planning department may well refuse an application and also take action against you if you rebuild without permission.
Nav786
by Nav786 » Sun Aug 07, 2022 12:07 am
I thought that might be the case. I just wanted someone with knowledge give me advice.
Thank you
It is currently Wed Dec 04, 2024 8:44 am
