Hi all
Can the below cable be used for a light circuit? Have already run a length of cable however messed up with what was actually need in terms of power and switch. Hoping to be able to use this multi core cable as a single run ~5m rather than having a second cable
Manufacturer Helukabel; Part 83675
Technical data Special PVC control cable with oil resistant outer sheath to DIN VDE 0285-525-2-51/ DIN EN 50525-2-51 and UL-Style 2587
compound type TI2 to DIN VDE 0207-363-3 / DIN EN 50363-3 and class 43 acc. to UL-Std.1581
Temperature range HAR flexing -5°C to +70°C;
fixed installation -40°C to +70°C;
Temperature range UL/CSA flexing -5°C to +90°C
fixed installation -40°C to +90°C
Nominal voltage HAR U0/U 300/500 V
Nominal voltage UL/CSA 600 V
Test voltage 3000 V
Breakdown voltage min. 6000
