What tool do I need to get the cartridge on this tap?
joejoeB
by joejoeB » Thu Aug 04, 2022 11:48 pm
Hi everyone, I have a leaking monoblock dual lever tap and have got as far as turning off the water and removing the lever and outer housing, but I'm at a loss as to how to remove the cartridge from the tap.
All of the how-to videos seem to have cartridges where there's something to get a spanner on to, but this tap seems to have a sunken fitting - do I need some sort of hexagon-shaped tool to fit the hole so I can turn it?
Might be clearer from the pic.
Thanks for any help!
Tap with the lever & housing removed.
Re: What tool do I need to get the cartridge on this tap?
by stoneyboy » Sat Aug 06, 2022 9:58 pm
Hi joejoeb,
Possibly try a box spanner, different manufacturers use different thickness material for the same internal dimension so you may have to shop around.
It is currently Sun Dec 22, 2024 4:02 pm
