kitchen tap
7 posts   •   Page 1 of 1
cesca
kitchen tap
by cesca » Mon Aug 08, 2022 5:50 pm
My kitchen tap is leaking (the tap itself, not underneath the sink). So far it is under control because there's a lot of limescale around it. It's around 50 mm diameter, but the specifications I see online do not mention it and in some cases it says 40 mm.
Does it matter?
Re: kitchen tap
by stoneyboy » Wed Aug 10, 2022 10:33 pm
Hi cesca,
I'm not sure what you are asking about.
If it's the fact it's leaking - no it doesn't matter, put up with the limscale.
If it's the size of the tap - yes it does matter if you are going to try to renovate it. Replacing the whole tap will be the least frustrating way of dealing with the problem.
cesca
Re: kitchen tap
by cesca » Thu Aug 11, 2022 11:55 am
stoneyboy wrote:Hi cesca,
Hi stoneboy, thanks. Sorry, my post was not very clear. The limescale is a secondary problem. When I turn the water on, there's a minor leak from the area I've wrapped with a cloth. This is the main problem and, I think, the tab need to be replaced.
Most model specifications do not mention the diameter size. The new tab should have the same dimensions of the old tab, shouldn't it? How/Where can I find them? Thanks again.
Re: kitchen tap
by stoneyboy » Thu Aug 11, 2022 10:32 pm
Hi cesca,
If you search the web site of the company that fixes screws there are a number of similar taps for sale. If you have mains fed hot and cold the tap diameter will not matter, if however you are on tank fed hot with a low pressure you may find the flow too slow. In this case you will have to pay for a Franke navora which internally copes better with low pressures.
cesca
Re: kitchen tap
by cesca » Fri Aug 12, 2022 10:49 am
Hot and cold water are fed by the mains (will ask a plumber about pressure etc.). In case I want a different model and (if only for aestetical reason) find out the tap diameter, would the word in the specifications be ''diameter'' or something else?
Thanks again.
Re: kitchen tap
by stoneyboy » Fri Aug 12, 2022 10:33 pm
Hi cesca,
With mains fed supplies you can have any tap you like, they will all work.
cesca
Re: kitchen tap
by cesca » Sat Aug 13, 2022 4:00 pm
Thanks stoneyboy.
It is currently Mon Nov 25, 2024 11:56 am
