Is this fireplace safe after removal?
wezzoid
by wezzoid » Tue Aug 09, 2022 8:03 pm
This fireplace had a gas fire with back boiler. I don't want a fire anymore, going to make it tidy and put a houseplant in there or something.
Where the equipment was originally installed they must have taken a lot of brickwork out of the right hand side to do it. All there is now is the single skin of bricks at the front, and on the right side they've loosely piled in bricks and cemented them, which doesn't look to me like it'd bear a lot of load.
The opening was reduced. I chipped away to reveal the extent of the original concrete lintel, and below that there's some bricks stuffed in loosely, cemented, and flat steel lintel at the bottom to support that, which seems fine i suppose.
https://imgur.com/a/lPv7sVq
Re: Is this fireplace safe after removal?
by stoneyboy » Thu Aug 11, 2022 10:46 pm
Hi wezzoid,
Provided 2 brick thick return walls have been left either side there's the not much to worry about.
wezzoid
by wezzoid » Sun Aug 14, 2022 5:10 pm
i had a bit of a google but i don't understand what a return wall is in this context. My pictures show it's only one brick thick, but maybe im thinking of the wrong bit.
Better photos:
https://imgur.com/a/W9xrpC1
by stoneyboy » Sun Aug 14, 2022 10:07 pm
Hi wezzoid,
Either side of the fireplace opening you have return or buttress walls. The left one which is 2 bricks thick is fine but the right one has had nearly all the bricks removed.
YOU FIREPLACE IS NOT STRUCTURALLY SOUND.
Before you remove any more bricks you must reconstruct the right buttress to be 2 bricks thick (so it duplicates the left one) and have allowed time for the mortar to set.
wezzoid
by wezzoid » Sun Aug 14, 2022 10:26 pm
thanks stoney. I was a absolutely not going to remove any more bricks, i just wasn't sure if it needed reinforcing and how to do that if it does
It is currently Sun Nov 24, 2024 1:15 pm
