green coating under old wallpaper
pickycharlie
by pickycharlie » Tue Oct 09, 2007 3:20 pm
I am decorating a room in a house built 1912. Under the many layers of wallpaper there is a green powdery coating on the walls. Is this old paint? If so, if it is lead based paint can I paint over it with emulsion or a specialised paint or do I have to wallpaper. It is going to be a children's room so I want to make sure it will be safe.
pablo2
by pablo2 » Fri Oct 12, 2007 10:21 pm
Hello
It's unlikely to be lead as this was used for woodwork , most probable is distemper if the surface is chalky you will need to wash it down and apply a coat of Artex stabiliser then paint as normal.
pickycharlie
by pickycharlie » Sat Oct 13, 2007 9:32 pm
Thanks,
I think the walls are going to be a bit of a mess so I've been told best to put lining paper on. do i need to prime the wall first?
It is currently Fri Nov 22, 2024 5:43 pm
