Connecting Dishwasher problem
scoobyandy
by scoobyandy » Tue Oct 09, 2007 6:18 pm
I want to connect my table top dishwasher to a cold water tap on my sink. has anyone got any ideas on how i can do this.
Thank you in advance.
Bay Plumbing
by Bay Plumbing » Sun Oct 21, 2007 12:08 pm
due to water Regs you may not be able to find a connection for your tap as this can cause backflow into your cold water supply you will need to get a plumber in to connect to the existing cold supply pipe and depending on how old the d/washer is you may need a single check vavle (as new d/washer come with this installed in inlet hose) on you cold supply to stop above happening.
Mark
It is currently Thu Dec 26, 2024 1:24 am
