Single Hot Water Tap Not Working
reckoner
by reckoner » Fri Aug 26, 2022 3:40 pm
Water has stopped flowing from our bath hot water tap. All other taps are working. When I turn the water mains off the flow stops for all cold taps, but still flows through all hot taps except the bath. Any help appreciated. Many thanks.
Re: Single Hot Water Tap Not Working
by stoneyboy » Sat Aug 27, 2022 11:57 pm
Hi reckoner,
Most likely an air lock in the pipe work feeding the hot tap. If you have access to a wet vac use this to suck on the hot tap - fully open. If not try linking the hot and cold taps and turning them both on - hot first.
It is currently Sun Jan 05, 2025 7:01 am
