Consumer Box in Shed
grahamparkinson
by grahamparkinson » Sat Aug 27, 2022 11:50 pm
I am looking at putting and electric supply into my shed via Consumer box, the intake is 3 core wire, with 3 outlets which is 2 core wire, 1 for light, 1 for sockets and 1 switch box for outside filter and pond pump and lights. The input on the switch box for the filter, pump and outside lights has 3 connections one earth, live and neutral do I just attach the live and the neutral from the consumer box, my work will be checked by a qualified electrician.
Re: Consumer Box in Shed
by Mr White » Sun Aug 28, 2022 10:18 pm
No. You MUST have an earth connection. You must also have an RCD (But that can be indoors) or RCBO's
I would suggest you ask your electrician to visit site and tell you what he is prepared to let you do. After all, it will be his name/signature on the paperwork.
by ericmark » Tue Aug 30, 2022 2:12 pm
This https://electrical.theiet.org/media/169 ... ilding.pdf is dated, written before we needed all circuits RCD protected with a type A 30 mA RCD, but it is still a good guide.
Fig 3 is the bit which causes the most problems, with a TN-C-S supply we worry about the broken PEN more about that here https://electrical.theiet.org/wiring-ma ... roken-pen/ so we need to be careful outside as although a MCB or RCD may remove the line and even the neutral, it leaves the earth connected, and if the true earth is a different voltage to the DNO earth current can flow between the two.
In Wales where I live work in the garden is considered as a special location, and needs registering with LABC, this requirement was removed in England, but we should aim to use all class II items in the garden, there has been of late problems with hot tubs, patio heaters, and EV charging points due to using class I equipment, and the cures can be quite complex.
The general public watch an electrician at work and think that's easy, but it's the bits you can't see, all jobs start with a method statement and risk assessment, that's all, not just electrical in many cases this may take seconds, for example there's the stop tap, likely water supply follows this route. Same with electrics, I survey the site, and normally quickly assess the risks.
But when remote from the site, this is hard, hence the links, it was a 5 year apprenticeship that I did, I like to think there was a reason it took so long, and that was not that I am a slow learner.
It is currently Thu Dec 12, 2024 5:49 pm
