Repointing Bradstone blocks
Frejaviole
by Frejaviole » Fri Sep 02, 2022 10:38 am
I have repointed parts of my garage that's built with Bradstone blocks but the pointing only seems to stay for a year or so before it 'falls out'. It doesn't crumble just comes out in brick-length pieces.
Is there any bonding agent that I could use to keep the poinig 'stuck'? Or is it my poor workmanship?!!
Re: Repointing Bradstone blocks
by stoneyboy » Sun Sep 04, 2022 10:31 pm
Hi frejaviole,
Most likely issue is that the joins were dry when you repointed, the water in your mortar mix will have been sucked out so does not adhere or set at the edges. If this is the case thoroughly wet the joins before you start.
Frejaviole
by Frejaviole » Mon Sep 05, 2022 12:45 am
Many thanks - I'll try that but is there any point in adding a bonding agent as well?
by stoneyboy » Mon Sep 05, 2022 9:36 pm
Hi frejaviole,
Assuming the mortar joints have been raked out to a depth of about 25mm there should be no need for a bonding agent. You could add one to your mortar mix and with the bradstone blocks you will end up with an impervious wall. Whether this will be a good thing will depend on the area of the parts that are treated.
It is currently Thu Dec 12, 2024 1:06 pm
