by John Joe 1967 »
Tue Sep 06, 2022 7:35 pm
I am going to replace my existing internal doors. My house is nearly 100 years old. The existing door casings are not perfect i presume due to settlement. If the head of the door lining is out of level, would you cut the top of the door, (so the door is then longer on one side) to try to follow the door lining head. If you were to do so, what would be the most you would trim. I felt 6mm maximum. It would create too many other problems to take the door casing out.
