by ericmark »
Thu Sep 22, 2022 4:00 am
The length of the immersion is only important when fitted on the top of the tank, years ago we would fit duel length immersion heaters long one for bath and short for hand washing, the Irish use an immersion outside the main tank, the Willis system, and that uses time to work out how much water is heated.
But with off peak systems the bottom thermostat runs when on cheap rate, and the higher on set to a lower temperature only when boost button is pressed.
