Filling 25mm holes in plasterboard from TV mount
chenks
by chenks » Mon Oct 10, 2022 10:41 am
i fitted a tv mount to a plasterboard wall a while ago using 25mm gripit mountings.
i've now come to a time where it needs to be removed and the holes filled in the plasterboard.
i have 5 x 25mm holes in the plasterboard that need filled.
looking for a method to successfully fill, so that once sanded and painted they can't be seen.
i thought about buying rubber bungs (which are for 25mm holes), pushing them into the hole leaving a few millimetres to fill. would this work?
chenks
Re: Filling 25mm holes in plasterboard from TV mount
by chenks » Mon Oct 10, 2022 2:28 pm
to clarify, as the opening post may not have been as clear as it should.
the holes are 25mm in diameter, not depth.
It is currently Sat Nov 23, 2024 2:53 pm
