Decommissioning Switched Fused Spur
nohammers
by nohammers » Sun Oct 16, 2022 11:42 am
Extremely newbie question! I'm looking to remove a redundant electric fireplace heater - it's wired into a switched fused spur on the wall, which won't be used again after the heater's removed. The spur is always switched off, and I don't want to remove the actual box it's housed in. Both ingoing & outgoing cables are your standard mains three-wire ones, like with lights and appliances.
I know to turn off the power etc before touching anything in there, but is it safe to unscrew the outgoing wires (the ones connected to the heater) and keep the ingoing wires screwed in? As long as it's always switched off?
(Equally, would it be dangerous if it ever got switched on? It seems like this should work on the same principle as a normal plug socket, but I want to make sure!)
Or if that isn't safe, what's the best way to disconnect and isolate the ingoing wires while keeping them all inside the box?
Re: Decommissioning Switched Fused Spur
by stoneyboy » Mon Oct 17, 2022 10:03 pm
Hi nohammers,
Turn off all your electric, remove the faceplate then undo the connections marked "load" and clamp, if there is one. You should then be able to remove the heater cable completely. The incoming earth must remain connected. Tighten the connections (even though there is nothing in them) and refit the faceplate. If the cable came out of the faceplate and there is a hole, you must fill this so nothing can be poked in.
Turning the FS on and off should not have any effect.
It is currently Thu Dec 12, 2024 5:37 pm
