I paid welding shops 4 times to fix in 2022 and still not fixed
Help, advice and questions answered on all types of metal joinery
Thebossisagirl
by Thebossisagirl » Fri Oct 21, 2022 4:23 am
I have a David Brown 1200 tractor. There's a metal hydraulic tube that connects to the under side of the tractor with 2 bolts, an o-ring and gasket. It was dripping so I took it off and went to a welding shop where they recommended I have it brazed.
2-4 weeks later, it started dripping hydraulic fluid again, getting worse every day. The leak is where the tube meets the connector part. So far this year I've had it brazed 4 times ($40 each) and it's leaking again now. I've been using the top reputable welding shops. Suggestions? Thanks.
Re: I paid welding shops 4 times to fix in 2022 and still not fixed
by ericmark » Sat Dec 10, 2022 3:20 am
If the pipe has work hardened then it will likely re-crack after brazing or welding, to anneal the pipe may work, but heat treatment is specialist work, and since the pipe seems to have original paint on it, it clearly has not been heat treated.
But since you say $ not £ I assume not UK, only time I have worked with $ is in Hong Kong, which is no longer British, so can't really recommend anyone to use.
TheDoctor4
by TheDoctor4 » Wed Nov 22, 2023 1:14 pm
[quote=Thebossisagirl post_id=129539 time=1666322635 user_id=111488]
[/quote]
This is teh test text added to the post here
TheDoctor4
by TheDoctor4 » Wed Nov 22, 2023 3:58 pm
This is a test reply to this post
Bolt Text
Italic Text
Underline
quoted object
Code: Select all
<?php echo''some code goes here"; ?>
  • list
  • list
  • list
  • list
  • list
[*]stuff here
https://www.diydoctor.org.uk/images/diy ... y-logo.png
font colour
It is currently Sun Dec 22, 2024 4:07 am
