How is this water getting in?
BullBates1
by BullBates1 » Thu Nov 03, 2022 7:58 am
Any suggestions on how this water is getting in? I previously thought it was my broken external cill however I have had this re-built
There is no visible damp from above, it's like it is coming directly through the wall at that location but there is no obvious damage to the wall outside
Re: How is this water getting in?
by stoneyboy » Fri Nov 04, 2022 9:49 pm
Hi bullbates1,
If you are referring to the small damp patch below the window sill, this may be a particularly porous patch in your solid walls.
If you are referring to the staining emanating from the sill box section of the window, it may be that a drain path has not been made for the condensation forming inside the window sections.
It is currently Sat Nov 23, 2024 10:44 am
