Bike rack in concrete blocks
AndyEssex
by AndyEssex » Sun Nov 06, 2022 6:29 pm
Hopefully this is the right place to post.
I installed a bike rack on the wall in our garage today, it has breeze block style concrete blocks.
There was already a screw in the wall from the previous owners, it was in the right location so I decided to use that as a starting point rather than drill another hole.
The rack went up and held the weight of the bikes but then I heard bits of the concrete block falling off the wall.
I quickly took the rack down to find concrete had fallen away around the initial screw that I used. Not sure what caused this but I can only suspect it was slightly damaged before I began and I didn't notice.
Attached are some pictures to help explain.
What are my options for filling this hole in, is there a concrete-esque polyfiller product on the market?
Can I continue to use this hole for the bike rack , perhaps with a longer screw? I'd like to avoid having to drill another four holes in a new space.
General question, I'm using 50mm screws albeit they are going through a fairly thick bike rack frame, should I be using longer screws?
Many thanks for any help and advice - typically thought it had gone far too well!!
AndyEssex
Re: Bike rack in concrete blocks
by AndyEssex » Sun Nov 06, 2022 6:39 pm
I cannot seem to upload images so here is a link to three images: https://drive.google.com/drive/folders/ ... _1WUrPg3AT
The successfully installed bike rack before removing it.
The damaged hole that was already there.
One of the fresh holes I drilled which looks fine.
It is currently Sat Nov 23, 2024 1:44 pm
