Exterior Drain with a bar running through it?
alexleigh
by alexleigh » Mon Nov 21, 2022 1:42 pm
Hi Guys,
I have an exterior drain on a house I have recently bought that was full of silt. I lifted the cover and cleared all the sludge away. I am left with what looks like a brick surround with a thin bar running through it. It doesn't look like a drain at all? It has no pipes running into it. Any ideas what this is? It doesn't overflow so I guess water must be escaping somewhere?
Many thanks
Alex
Max G
Re: Exterior Drain with a bar running through it?
by Max G » Tue Nov 22, 2022 11:23 am
Im not a plumber but I am assuming that is some sort of drain or manhole, is that bar a handle to lift cover off? Try clearing around edges to free it for inspection? could be completely wrong though. cheers
alexleigh
by alexleigh » Thu Nov 24, 2022 5:24 pm
Hi Max,
Thanks for the reply. The bar seems to run into the brickwork so it isn't a handle. It was a good idea though!
Alex
It is currently Sat Nov 23, 2024 3:22 pm
