Shower controls not working and stiff
Hmh
by Hmh » Mon Nov 21, 2022 6:42 pm
My shower controls are very stiff and almost fully seized when I turn the boiler and hot water on.
I switch off the hot water and ran it just on cold and it works perfectly, as soon as the hot water goes on the controls stick.
I have 2 showers, it is the same for both.
I did take one apart to make sure it was not caked in scale but it all seemed okay.
Please help!
Drip-Doctor
Re: Shower controls not working and stiff
by Drip-Doctor » Tue Jan 17, 2023 3:53 pm
I assume when you took it apart you lubricated all the rubber o rings etc and bearing surfaces in silicone grease and tried to operte the internal workings outside the shower valve case so you could prove it worked before replacing? A photo would help, if not then perhaps a make/model of the shower or even whether it is an exposed and a concealed valve?
It is currently Sun Nov 24, 2024 7:23 pm
