Insulating semi-detached house floor from below
zakoro
by zakoro » Mon Nov 21, 2022 9:18 pm
Hello, I have looking to insulate the ground floor of my semi-detached house, where I have a basement with sufficient room to crawl under.
I was looking at the possibility of adding insulation from below, as I do not want to rip up the floorboards, however I run into the issue of not being able to install a VCL properly then.
I was also planning on laying 9mm ply/OSB over the current floorboards prior to install luxury vinyl planks, to ensure flat surface throughout. Could it be an option to install a VCL between the floorboards and ply? What other options do I have?
Re: Insulating semi-detached house floor from below
by stoneyboy » Tue Nov 22, 2022 10:11 pm
Hi zakoro,
Suggest you use fibreglass quilt or mats slightly thicker than joist depth and hold this in place using strong cord zigzagged over the bottom of the joists. No vcl needed.
It is currently Thu Jan 02, 2025 11:26 pm
