Mounting A Magnetic Contact Switch On A Curved UPVC Frame
heathman
by heathman » Sun Nov 27, 2022 4:16 pm
Hello,
I need to mount a flat, magnetic alarm contact to a curved UPVC window frame. I wondered if anybody has a solution for mounting it please?
I thought maybe cutting away a section of the curved part of the frame with the hope there's a flat surface underneath to mount the switch but have no idea what's inside a typical window frame. Another idea was to use some Milliput to form a base for it but could look shabby.
Any other ideas please?
Thank you very much.
Re: Mounting A Magnetic Contact Switch On A Curved UPVC Frame
by Mr White » Mon Nov 28, 2022 12:30 am
If you mount it on the curve how long before it gets knocked off? (Rhetorical question)
Mount it on the flat surface and use a bigger magnet or double the magnets.
Do test it with your meter before you fix it with screws
heathman
by heathman » Mon Nov 28, 2022 5:52 pm
Many thanks for the reply.
I think the flat surface will be beyond the 20mm range specified but no harm in trying I suppose.
by Mr White » Mon Nov 28, 2022 9:26 pm
I would suggest you read my post again.
Above is a "uPVC" door with magnet and contact, they are both overesized to overcome the gap. (Magnets doubled up also work, if you do it right.)
It is currently Thu Dec 12, 2024 4:44 am
