Attach Curtain Bracket to Wooden Plinth - Questionable Size
alewater
by alewater » Fri Dec 30, 2022 7:58 pm
Hi everyone,
Recently moved and looking to put up curtain poles but nearly every window has a wooden batten above the window.
This wouldn’t normally be an issue but where I’d like to attach the brackets would be very close to the top/bottom of the wooden plinth. Therefore imo not providing adequate fixation. See photo.
Don’t particularly want to remove the plinths as they are the same colour as the walls and I don’t have the paint to touch up.
The plinths are 45mm.
Thoughts on how to put the brackets up?
Re: Attach Curtain Bracket to Wooden Plinth - Questionable Size
by stoneyboy » Sat Dec 31, 2022 10:54 pm
Hi alewater,
1. Cut the bottom keyhole off the bracket and use top hole only - you may find the batten is only stuck to the wall so you will have to screw into the wall below.
2. Buy a different bracket.
3. Remove the batten and buy some paint.
alewater
by alewater » Sun Jan 01, 2023 12:17 am
Thank you.
The plinth us screwed in multiple places to the wall.
The bottom of the plinth is 100mm up from the window so I going to put the brackets directly under the plinth using two brown wall plugs.
alewater
by alewater » Sun Jan 01, 2023 7:52 pm
I drilled a pilot hole just below the plinth and 30mm in I hit metal. It also sounds hollow below the length of the plinth where it sounds "normal" above it.
Now I'm more confused.
by stoneyboy » Sun Jan 01, 2023 9:40 pm
Hi alewater,
Very likely that you have steel lintels above the window opening so you will have to screw into these. Once you have drilled a pilot hole in the steel any hardened steel wood screw should be ok.
It is currently Sat Feb 01, 2025 7:37 am
