Unusual light switch
bcsmith
by bcsmith » Thu Oct 11, 2007 5:28 pm
I am trying to check out a fault in a lighting circuit. The existing (double) switch is unusual: the 2 rockers fill the whole of the front face so the usual pair of screws are missing and there is no other obvious means of removing the switch body from the box. Any suggestions please.
BLAKEY1963
Re: Unusual light switch
by BLAKEY1963 » Thu Oct 11, 2007 11:48 pm
[quote="bcsmith"]I am trying to check out a fault in a lighting circuit. The existing (double) switch is unusual: the 2 rockers fill the whole of the front face so the usual pair of screws are missing and there is no other obvious means of removing the switch body from the box. Any suggestions please.
Thanks[/quote]
BCSMITH
DOES THE RIM AROUND THE SWITCHES CLIP OFF TO REVEAL
SMALL SIDE SCREWS . TO UNSCREW SWICHES ?
ISOLATE SUPPLY , IF U MANAGE TO STRIP DOWN.
BLAKEY1963
bcsmith
by bcsmith » Fri Oct 12, 2007 9:14 am
Thank Blakey1963.
I guessed that the answer lay under the rim or under the rockers: but neither seemed to want to move and hate to smash anything unecessarily. With your suggestion tried harder on the rim then discovered that the rockers themselves would prize off. Loose wire now sorted: thanks.
It is currently Tue Jan 14, 2025 11:46 am
