Cavity wall insulation with 40mm cavity
rikkik
by rikkik » Mon Jan 09, 2023 5:07 pm
Hiya, anyone know of a solution to install cavity wall insulation when the cavity is only 40mm deep? The companies I've tried which have used polystyrene balls have all said its 50mm minimum and they wont do it as there will be cold spots (and trouble down the line). But surely it must be possible with smaller balls? Any ideas much appreciated.
Re: Cavity wall insulation with 40mm cavity
by stoneyboy » Thu Jan 12, 2023 10:21 pm
Hi rikkik,
Suggest you make enquiries about blown fibre CWI and see if the same restriction ]s apply
rikkik
by rikkik » Fri Jan 13, 2023 12:11 pm
thanks S. will look into that.
Has anyone attempted DIY cavity wall insulation? Or is that crazy talk?
by stoneyboy » Fri Jan 13, 2023 10:23 pm
Hi rikkik,
Yes that’s crazy talk!
It is currently Thu Jan 02, 2025 11:22 pm
