Turning a toilet waste pipe into a drain
earthgate
by earthgate » Fri Jan 13, 2023 9:28 am
I have old type waste pipe 1960's ish into the ground in toilet. I need to move the toilet, but wanted to turn the outlet into a drain for wet room. Is it possible, I assume i need some sort of none return fitting?
Re: Turning a toilet waste pipe into a drain
by stoneyboy » Sat Jan 14, 2023 11:24 pm
Hi earthgate,
Yes you can but you must incorporate a trap of some sort. Solutions - cap the soil pipe with a stop end which has a socket for 40mm waste pipe, fit shower trap onto this; .dig down and convert the pipe to plastic soil pipe and use plastic fittings to connect the shower trap.
earthgate
by earthgate » Mon Jan 16, 2023 5:00 pm
Hi stoneyboy,
Pipe is clay and 200mm I assume I'm going to have to dig it out?
by stoneyboy » Mon Jan 16, 2023 10:44 pm
Hi earthgate,
It is just the collar that is 200mm, once you remove this you will find a 4” clay pipe. If you wish to join 110mm plastic to this you can buy a rubber joiner which is specifically designed for this with two jubilee clips.
earthgate
by earthgate » Tue Jan 17, 2023 9:01 am
Hi stoneyboy,
you're a star!, thanks
It is currently Sun Dec 22, 2024 5:41 pm
