Chalet bungalow eaves insulating
alberttrotter1
by alberttrotter1 » Mon Jan 23, 2023 2:18 pm
My chalet bungalow has the 4 eaves so the loft walls are single skin block work with only thin polystyrene sheets on the underside of the roof. I'm considering using 50mm insulating board against the block work and between the roof joists but wanted views and advice before starting to pay out for supplies. Any help appreciated
Re: Chalet bungalow eaves insulating
by stoneyboy » Wed Jan 25, 2023 10:59 pm
Hi alberttrotter1,
If you have triangular eaves spaces formed by the floor, loft walls and roof and they are storage rather than living space, then concentrate on insulating the loft walls and perhaps the floor.
alberttrotter1
by alberttrotter1 » Thu Jan 26, 2023 10:48 am
Stoneyboy, thanks for the reply. Due to the hatch size, would I be able to do the vertical walls with just insulating roll rather than boards and if so would I need to Batton out to create ventilation?? Regards
by stoneyboy » Thu Jan 26, 2023 11:02 pm
Hi alberttrotter1,
Better to use boards - cut them to fit through the loft hatch and then reform them. Stick them in place with the sticky foam stuff and fill any gaps with expanding foam. Regards S
It is currently Sun Dec 22, 2024 4:05 am
