New socket for wall mounted TV
Missing_fingers
by Missing_fingers » Thu Oct 11, 2007 9:54 pm
My dear wife has assured me that i will be intalling a new flat screen telly in my kids room for Christmas, obviously this is to be on a wall with no sockets currently on it....
Any advice would be welcome on the following points
1) I have seen height restriction in Part P for outlets - Does this also cover for an appliance mounted at mid wall height?
2) Would a fused spur be better than a DSO?
3)Can i run the coaxial cable (75 Ohm) in the same chased and buried trunking as the live feed or will the electric cable cause too much interfer.. interfren... muck up the TV signal?
Cheers folks.
Mr Mising_Fingers
by sparx » Fri Oct 12, 2007 10:47 pm
Hi, socket heights only apply to new build & 'substantial refurbishments'.
No as most new appliances have moulded plugs & cutting them off invalidates warentees.
No must be at least 50mm apart, never mind signal, leckie regs say seperate/segregate circuits,
regards SPARX
Missing_fingers
by Missing_fingers » Sat Oct 13, 2007 12:25 pm
Thanks Sparx.
Looks like I'll be chasing out with a larger bolster then! Best get some advice on the plastering page!
Thanks for the help.
Missing Fingers
It is currently Tue Jan 14, 2025 10:12 am
